ricci1
Dec 29, 2021Tutor
NETGEAR - Orbi RBK753S AX4200 WiFi 6 Mesh System- wifi issue
Thnak you in advance for the help. I upgraded my internet plan to gigabit form Xfinity. I currenlty live in Houstin Tx. The service provides 1.2 gigabits upload and 35 download. I have an Arris Sb-8...
ricci1
Dec 29, 2021Tutor
Thank you for the link. I will look in to agregation. I have not hard wired the satelites. I was told by bnetgears is not stable to do so, I have a ethernet port next to both satelites so that would be an easy set up- Do you have any licks on how to hardwire the satelites.
Dec 30, 2021Guru - Experienced User
I've had great luck with a wired backhaul on my orbi's. Pretty easy to setup.
- ricci1Dec 30, 2021Tutor
after much consideration I lowered my ISp sped to 900/20. Wan agregation would be benefitial if I am over the 1mgbs correct ? Also should I just try to wired backhaul as referenced above ?
I connected the satellites as instructed on the link and my speeds have dropped significantly. Both Satelites are geetting fed from a multiport swicth that is gigabit.
- plemansDec 30, 2021Guru - Experienced User
Hardwire into each satellite and test the speed. that'll let you check the backhaul speeds. Maybe a bad cable/switch port is causing it to drop to 10/100mbps connection versus gigabit.
