ricci1
Dec 29, 2021Tutor
NETGEAR - Orbi RBK753S AX4200 WiFi 6 Mesh System- wifi issue
Thnak you in advance for the help. I upgraded my internet plan to gigabit form Xfinity. I currenlty live in Houstin Tx. The service provides 1.2 gigabits upload and 35 download. I have an Arris Sb-8...
ricci1
Dec 30, 2021Tutor
after much consideration I lowered my ISp sped to 900/20. Wan agregation would be benefitial if I am over the 1mgbs correct ? Also should I just try to wired backhaul as referenced above ?
ricci1
Dec 30, 2021Tutor
I connected the satellites as instructed on the link and my speeds have dropped significantly. Both Satelites are geetting fed from a multiport swicth that is gigabit.
- plemansDec 30, 2021Guru - Experienced User
Hardwire into each satellite and test the speed. that'll let you check the backhaul speeds. Maybe a bad cable/switch port is causing it to drop to 10/100mbps connection versus gigabit.
