prue
May 12, 2020Aspirant
NETGEAR -Orbi AC2200 Tri-Band Mesh Wi-Fi System RBK43-200NAS
I’m trying to get help on the Orbi AC2200 Tri-Band Mesh Wi-Fi System RBK43-200NAS but it’s not an option under model. I’m not getting the speeds in the upper corner bedroom. I have the router place...
May 12, 2020Guru - Experienced User
- prueMay 12, 2020AspirantThanks.
I’ll get you the responses.
Meanwhile, how do I find out nearby WiFi neighbors? We do have neighbors using WiFi.
Thank you.- FURRYe38May 12, 2020Guru - Experienced User
Load up any wifi analyzer app on a pad or PC.
https://itunes.apple.com/us/app/network-analyzer-lite-wifi/id562315041?mt=8
http://www.nirsoft.net/utils/wifi_information_view.html
https://www.acrylicwifi.com/en/wlan-software/wlan-scanner-acrylic-wifi-free/
https://lizardsystems.com/wi-fi-scanner/screenshots.php
http://nutsaboutnets.com
http://www.metageek.com/products/inssider/
