wlmasonii
Aug 07, 2019Aspirant
Netgear 7300 will no longer connect to Orbi after Orbi firmware update V2.3.5.3
I have two Netgear 7300 extenders connected to my Orbi network. After completing the most recent Orbi firmware update neither extender will reconnect to the Orbi router. The extenders recognize ...
Aug 07, 2019Guru - Experienced User
I believe there was a recent post about someone with a EX7700 that would no longer connect to Orbi.
I recommend you open up a support ticked and let NG know about this:
https://www.netgear.com/mynetgear/registration/login.aspx
Would be interesting to see if they connect if you disable WPA security on the Orbi system. Re-enable after testing.
wlmasonii
Aug 08, 2019Aspirant
Interestingly, the Netgear 7300 would not connect to the Orbi router even with password security turned off.
