danbob6
Jun 25, 2019Aspirant
Netgear account password vs. Netgear admin password
About one week ago I received an email from Netgear advising me that I could update to the latest firmware for my RBR20. I tried launch the Orbi app, which is on my iPhone, but was stymied because I...
- Jun 27, 2019
danbob6 wrote:
..particularly since one question (What is your mother's middle name) isn't one I would have choosen, since she didn't have a middle name.Interesting. Adds weight to my theory.
The depressing thing is that this bug in password recovery has been around for some time. I would have thought that they would have squished it in the Orbi range. Seems not.
There is support for the Orbi WiFi System, including a manual, somewhere at the end of this link:
>>>> Orbi RBK50 | WiFi System | NETGEAR Support <<<<
There is a section in the Orbi manual Change the admin Password. It explains how to Enable Password Recovery. These days Netgear seems to turn that on by default. So you may have to get in there and turn it off. Or set it up with your own questions and answers.
danbob6
Crimpon (Prodigy)-
Thanks for your quick response.
As you suggested, I normally keep my important passwords in several different places, but it seems I out-smarted myself in this instance, since I seem to have done a killer job of hiding this particular passwork, as well as the answer to my 'secret questions.'
I do have two follow-up questions, though. Relating to your last comment about the WiFi name and passwork being on the label, which abel are you referring to?
Also, what is the impact of doing a factory reset?
Thanks
Danbob6
CrimpOn
Jun 25, 2019Guru - Experienced User
On my Orbi, there is a small sticker on the bottom that has the WiFi name ("OrbiXX") and the network key (password).
After a factory reset, the Orbi is exactly like it came out of the box, unless the firmware has been updated. It remembers nothing that was done to it except firmware updates. So, if you gave it a WiFi name (SSID) that is more interesting than "OrbiXX" and a new password, it doesn't know that anymore. It also does not remember any device IP assignments that have been made or any device names that have been customized. Doesn't know if you changed the DHCP range.
In my case, I have over 30 devices that I have (very) carefully assigned specific IP addresses (all the security cameras together, all the smart plugs together, all my Tivo machines together, etc.) I gave the network printer a specific IP address because it kept getting "moved" when a power outage would make the Orbi reboot. All that stuff is GONE after a factory reset. That's why people really do not want to do it unless there is no other option. Alas, you are stuck. You can keep the Orbi running as is, but not be able to access it until you somehow come up with the password. Or, you can bite the bullet and "start over."
Good Luck!
- danbob6Jun 25, 2019Aspirant
Thanks for your very complete explanation re: factory reset. Given the particulars of your situation, I can definitely understand why doing a reset is to be avoided at all costs.
In my case I only have one device, so I may go ahead and bite the bullet, when I have some time. By the way, this whole thing started for me when I got an email from Netgear telling me I should update my firmware. In your opinion, is it worth doing such an update?
Thanks again.
Danbob6
- CrimpOnJun 25, 2019Guru - Experienced User
My position is, "oh, yes. Do the update." Every update I have done in the past two years has made things better. Some people have had issues with updates, and the Forum has plenty of examples of "horrors". If it happens that you update and suddenly the Orbi fails to meet your expectations, you can always go back to a previous firmware.
- danbob6Jun 26, 2019Aspirant
Will do.
Thanks again for all your help.
Danbob6
