Walt_S
Jun 05, 2021Aspirant
Netgear Armor and DoS
I've been plagued with DoS attacks, some of which seem to be taking my router off-line for a few minutes until it recovers. From reading forums, I gather that this is because the buffer that holds u...
CrimpOn
Jun 07, 2021Guru - Experienced User
Walt_S wrote:I'm wondering if the Netgear Armor product will help this in any way?
I doubt very much that Armor would have any effect on DoS attacks.
I also doubt very much that DoS are having a serious effect on your Orbi system.
I have collected the logs from two Orbi systems for almost two years.
Both systems log these "DoS attacks" every day of every month, and neither system seems to be affected.
Netgear has an algorithm that looks at patterns in connection attempts to see if they fit specific profiles. If they do, then a note is put into the Orbii file if the user has selected that option. There are options to quit doing the DoS analysis and to quit logging the results. Both would (in theory) free up processor resources, although no one seems to know how much or if it would be significant.
I am not aware of any method to report the amount of available "buffer space". The Orbi debug page does show the number of connections in use. Out of 65,536 possible connections, my Orbi is now using 1,941. This is on the web page http://orbilogin.net/debug.htm
What are the specific symptoms that lead you to believe the Orbi has gone "offline"?
Walt_S
Jun 09, 2021Aspirant
Thanks for the info on Armor. I kind of thought that would be the case, but decided to ask anyway.
I get many log entries relating DoS attempts, and occasionally one is picked up by my FingBox which (among other things) monitors Internet Connectivity. I had originally been blaming my ISP for the numerous outages I'm experiencing, but then I noted a correlation between FingBox reports of network outages with some of the DoS entries in the Orbi log. For example, the FingBox reported offline at 02:19 this morning, and return to onliine at 02:27. Here is the log entry from Orbi:
[DoS Attack: TCP/UDP Chargen] from source: 199.195.249.122, port 58736, Wednesday, June 09, 2021 02:19:35
and at 2:30, the Orbi was assigning DHCP addresses:
[DHCP IP: 192.168.1.39] to MAC address 58:27:8c:ee:53:63, Wednesday, June 09, 2021 02:30:28
Which is from a NAS drive connected by Ethernte cable to the router.
I don't know if that helps. The only other advice I've gotten is to change my Internet-facing IP address, which my ISP refused to do.
Walt
