JRob555
Dec 18, 2019Aspirant
Netgear CM1100 modem and Orbi Issues
I have a Netgear modem that worked fine with a Netgear tri-band AC Nighthawk router (can't recall actual model). I upgraded and bought the Orbi with two satelites RBK 53 to increase the coverage. I've updated the firmware for both.
I can get both up and running, but anytime i reset anything I have a terrible time getting the modem and router to sync when I reboot. The ethernet lights on the modem go orange and the orbi disconnects. When connected to a PC, there error is that there is no ethernet connected to the Orbi. Also, if I plug an ethernet cable into the back of the Orbi from another computer, it totally crashes the system. I'd be greatful for any help! When it works the coverage and speeds are amazing.
- Retired_Member
JRob555 wrote:I have a Netgear modem ....
What is the model/type of this modem?
There is a NG modem that is dual (modem/router) that require special configuration
- Retired_Member
looks like the Netgear CM1100 is NOT dual. I beleive you said at one point it was working then you reset it?
- JRob555Aspirant
It's just a basic CM1100. No router. It's been working fine for over a year w/ a different Nighthawk router, but I've had challenges keeping it working w/ the new Orbi system. I've had to reset it a few time since I purchased it. I have to time the boot of the modem with the boot of the Orbi or I'll get the yellow ethernet lights. Takes me about 5 tries and then I'm afraid to touch it. Is it a DNS issue? Do I need to power off the satellites when I reboot the router? I'm just guessing but I don't think this is a sustainable situation.
