JRob555
Dec 18, 2019Aspirant
Netgear CM1100 modem and Orbi Issues
I have a Netgear modem that worked fine with a Netgear tri-band AC Nighthawk router (can't recall actual model). I upgraded and bought the Orbi with two satelites RBK 53 to increase the coverage. I...
Retired_Member
Dec 19, 2019
JRob555 wrote:Sorry - just to be clear: I should factory reset the Orbi, bring it online, connect w/ the satellites, then hook up to the modem?
No...if it were me I wouldn't worry about a factory reset at this point (unless you bought this orbi used..??). Normally the modem is set up first using the cable from your ISP outlet. Then run a ethernet cable fromm the modem to the Orbi router. At that point, if the Orbi settles down (no light on the upper rim) then try and hook up a PC to the Orbi (ethernet) and verify internet connection. From there try adding a sat.
Think of the way you had your system before the Orbi. The Orbi router now replaces the old NG router.
JRob555
Dec 21, 2019Aspirant
Thanks VAJim. I tried a lot of things and it was just too buggy. I re-hooked up my Nighthawk X6 and everything works flawlessly. I don't get the speed or the coverage using extenders but it works. I like the mesh concept a lot but I'll be returning this to Costco. Thanks for your help.
