daeaiaea
May 06, 2019Aspirant
Netgear CM1150v and ORBI RBR40 system issues
Please bear with me here as I am a networking rookie. I had ATT system for years and added Orbi RBR40 in last two years. constant issues with reliability of ATT service so a move to a new house nat...
- May 06, 2019
Reason for testing a PC directly to the modem is to rule out any problems at the modem first. IF something appears there that seems problematic, then the modem would need to be looking at first. If the modem and PC work fine with these sites, then the Orbi would need to be looked into next.
May 06, 2019Guru - Experienced User
With a wired PC directly connected to the CM modem, do you get internet and access various sites and speeds are ok? If so, then I would post about getting some help in the Orbi forum. This maybe a Orbi issue if the CM modem is working to spec and ISP says signal is good up to the modem.
