daeaiaea
May 06, 2019Aspirant
Netgear CM1150v and ORBI RBR40 system issues
Please bear with me here as I am a networking rookie. I had ATT system for years and added Orbi RBR40 in last two years. constant issues with reliability of ATT service so a move to a new house nat...
- May 06, 2019
Reason for testing a PC directly to the modem is to rule out any problems at the modem first. IF something appears there that seems problematic, then the modem would need to be looking at first. If the modem and PC work fine with these sites, then the Orbi would need to be looked into next.
pmassey
I have everything hooked up, have WiFi...... but cannot get on all the web-sites I need. I work from home. MUST be able to get on these sites!
May 06, 2019Guru - Experienced User
Need to verify first with a wired PC directly connected to the CM modem, do you get internet and access various required sites and speeds are ok wiht the modem only...
- pmasseyMay 08, 2019AspirantI did that. I can get on most sites, but a select view, ( that I need for my job) won’t let me get on.
- FURRYe38May 08, 2019Guru - Experienced User
I would check out a different modem and see if a different modem does the same thing. If not then I presume the CM1150v may need to be RMAd.
pmassey wrote:
I did that. I can get on most sites, but a select view, ( that I need for my job) won’t let me get on. - SeaMonkey80May 09, 2019Apprentice
pmassey wrote:
I did that. I can get on most sites, but a select view, ( that I need for my job) won’t let me get on.do you, by any chance, have Circle enabled on your Orbi? That thing is real buggy and blocks many sites for no good reason. If so, try disabling it.
