daeaiaea
May 06, 2019Aspirant
Netgear CM1150v and ORBI RBR40 system issues
Please bear with me here as I am a networking rookie. I had ATT system for years and added Orbi RBR40 in last two years. constant issues with reliability of ATT service so a move to a new house nat...
- May 06, 2019
Reason for testing a PC directly to the modem is to rule out any problems at the modem first. IF something appears there that seems problematic, then the modem would need to be looking at first. If the modem and PC work fine with these sites, then the Orbi would need to be looked into next.
daeaiaea
May 07, 2019Aspirant
FYI, just further follow-up, resetting the ORBI to factory seemed to fix everything late last night. a quick review of the ORBI forums led me to factory reset negating the need to even post a question.
thanks!!
May 07, 2019Guru - Experienced User
Glad it fixed it. Enjoy. :smileywink:
Visit the Orb forum again if needed. :smileyhappy:
