daeaiaea
May 06, 2019Aspirant
Netgear CM1150v and ORBI RBR40 system issues
Please bear with me here as I am a networking rookie. I had ATT system for years and added Orbi RBR40 in last two years. constant issues with reliability of ATT service so a move to a new house nat...
- May 06, 2019
Reason for testing a PC directly to the modem is to rule out any problems at the modem first. IF something appears there that seems problematic, then the modem would need to be looking at first. If the modem and PC work fine with these sites, then the Orbi would need to be looked into next.
pmassey
May 08, 2019Aspirant
I did that. I can get on most sites, but a select view, ( that I need for my job) won’t let me get on.
SeaMonkey80
May 09, 2019Apprentice
do you, by any chance, have Circle enabled on your Orbi? That thing is real buggy and blocks many sites for no good reason. If so, try disabling it.
