Doug-48051's avatar
Doug-48051
Luminary
Jul 20, 2017
NETGEAR Community Web Layout - SUCKS
The new community website uses a poor font and color schema for the threads.  The default font and color do NOT make for good reading. This may have a negitive impact on customer interaction.
I am more than willing to share my knowlege but gray letters on a white background seems a bad choices on some's part.  I was unable to type my post in this input box use IE-11. The new layout also seems to have issues with IE - 11.483.
  • Also, how do you easily tell the difference between read and unread messages?
  • What web browser and what operating system are you viewing the community forums with? Fwiw, IE has never complied with Web standards. Probably one reason IE is one of the least used Web browsers. Only about 15% of Web users use it.
    • Doug-48051's avatar
      Doug-48051
      Luminary
      ArtLee
       I mayself have multiple browser to use and test with. I was just providing feedback.
       If you think that excluding 15% of users is a sound business practice, maybe you should work for the Orbi Team. If you think 85% functionality is a reasonable outcome.  LOL
      • ArtLee's avatar
        ArtLee
        Apprentice
        Doug-48051 wrote:
        ArtLee
        I absolutely do not think excluding 15% of users is a sound business practice. I only suggest when coding web pages to established standards, then adding sniffer code for various I.E. versions so pages will also display well is a pain.
        Dont get me wrong, I've seen many other forums that look and work better than this one. In any case the thread is marked as solved.
