loomis1975
Sep 22, 2016Luminary
Netgear Contacted me to Write A Review
Netgear contacted me to write a review, which is fine, I just copied my review for Best Buy, but then they copied it into the clipboard and wanted me to post it at Amazon. Link went right to the pro...
DarrenM
Sep 23, 2016Sr. NETGEAR Moderator
Hello Loomis1975
That should be fine if you posted a review where you purchased the device.
DarrenM
UnCapitano
Sep 25, 2016Apprentice
I can post it for you. I actually posted a review on Amazon myself, even though I'd received mine from Best Buy. Great job, Netgear, but now I need that extra satellite.
- DarrenMSep 26, 2016Sr. NETGEAR Moderator
Hello Uncapitano
Thanks for the review and the satelites should be coming soon keep a eye on your vendors website.
DarrenM
