loomis1975
Sep 22, 2016Luminary
Netgear Contacted me to Write A Review
Netgear contacted me to write a review, which is fine, I just copied my review for Best Buy, but then they copied it into the clipboard and wanted me to post it at Amazon. Link went right to the pro...
UnCapitano
Sep 25, 2016Apprentice
I can post it for you. I actually posted a review on Amazon myself, even though I'd received mine from Best Buy. Great job, Netgear, but now I need that extra satellite.
DarrenM
Sep 26, 2016Sr. NETGEAR Moderator
Hello Uncapitano
Thanks for the review and the satelites should be coming soon keep a eye on your vendors website.
DarrenM
- itGeeksSep 29, 2016Apprentice
Darren when will the single router be avalible? In my very small apartment I only need a single, Also how much will it cost?
- DarrenMSep 29, 2016Sr. NETGEAR Moderator
I do not have the info at this time.
DarrenM
- peteytestingSep 29, 2016Hero
itGeeks wrote:Darren when will the single router be avalible? In my very small apartment I only need a single, Also how much will it cost?
im not sure there would be any logic in just buying this as a router alone esp if its price would be around $200 , you could get the r7000 for the same and have better wifi and feature set , unless that is you intend to move to a larger place and then buy a sat later on
