magafr
Apr 13, 2020Aspirant
NETGEAR D6000 & RBR40
i have installed my new ORBI (ORBR40 + satellite) plugging it into a wifi that was running with a D6000
it's working fine but there is something that I do not fully understand
I have now actually 2 different wifi at home
- 1 provided by netgear D6000 --> "wifi-netgear" (that is also a modem)
- 1 provided by Orbi --> "wifi-orbi"
both of them are working and i can connect to both of them to surf internet
but it looks to be quite stupid..
in my dining room (where i have both the netgear and the orbi, connected by wire) I have 2 wifi covering the room..??
i do not see the meaning of this!
is there any chanche to have only one of them?
morover.. is there any way to take advantage of the 2 devices to extend the coverage of the signal throught a same wifi network?
thanks a lot
1 Reply
Your modem already has a built in router and wifi, This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopI would try option #1 first...Review the user manual for the modem to get the modem bridged.
