ATbarker
Aug 07, 2022Follower
Netgear extensionfor RBR40
Have Router RBR40 and satellite RBW30 on the first floor, because the house is naroow and long. What can I add to strengten the signal in the basement?
- Aug 07, 2022
You can add another satellites.
Compatible models are:
RBS20
RBW30
RBS40
RBS40V
RBS50
RBS50Y
Keep in mind, the 50 series have a wider backhaul but will connect at the lower 866mbps backhaul the 40 series use.
Aug 07, 2022Guru - Experienced User
RBS20
RBW30
RBS40
RBS40V
RBS50
RBS50Y
