Gidg6640
Aug 12, 2020Aspirant
Netgear Genie & ORBI CBR40
Hello, Do I really need the netgear genie running on my computer (or at all) if we have the ORBI CBR40? Suddenly it seems to be taking up a bunch of memory and my hard drive is constantly running ...
- Aug 13, 2020
No, Genie isn't supported on Orbi systems.
So use the CBR40s web page to manage the system and you can use the Orbi app for simple use.
Aug 13, 2020Guru - Experienced User
