AniDutta
Jun 04, 2017Apprentice
Netgear Genie not working with Orbi on latest firmware
Can't login to the genie app anymore after the latest firmware update. Anyone else having similar issue? The Orbi is a great piece of hardware, but the software interface (app) is crappy.
- DarrenMSr. NETGEAR Moderator
Hello Anidutta
Are you able to use the orbi app and still use the web ui on the phone?
DarrenM
- AniDuttaApprentice
The Orbi app works, but it doesn't offer the functionality of pausing the internet on a device. My Orbi is in AP mode, and i cannot do that on the web ui. With the Netgear Genie app i was able to do it till the latest firmware update even in AP mode. After the latest firmware update, i cannot log in anymore.
Ani
The genie apps were not designed to fully work with orbi but they can because of similar coding right now the best way to access settings is the web ui.
DarrenM
- OrbiPhilipLuminary
The genie app on android works for me (V1.10.1.2) with one exception. Attempts to configure Guest Wifi state that it is not supported on my device. Obviously, that is not the case.
- AniDuttaApprenticeDarren,
For the amount of money, consumers expect a decent app. I call BS on your justification that web UI is the best way to interact with the system.
