dgwerder's avatar
dgwerder
netgear GS724TPS front faceplate ribbon cable installation
Replaced the fans however the front panel ribbon cables became disconnected (specifically the 2 cables which probably support the port LEDs since they no longer light) . These 2 ribbon cables are int...
