Vandergraff
Apr 06, 2021Apprentice
Netgear-Guest Open and Disabling Firmware Updates
As many have reported I often see a Netgear-Guest Open WiFi Network even when Guest Networks are disabled. I trraced the issue to one of my 3 satelittes - an RBS50Y. Netgear lists two firmwar...
Apr 07, 2021Guru - Experienced User
Did you factory reset the RBSY unit after the FW is updated and then set it up from scratch to see if the GN still appears?
- VandergraffApr 07, 2021Apprentice
FURRYe38 wrote:Did you factory reset the RBSY unit after the FW is updated and then set it up from scratch to see if the GN still appears?
Yes
