Vandergraff
Apr 06, 2021Apprentice
Netgear-Guest Open and Disabling Firmware Updates
As many have reported I often see a Netgear-Guest Open WiFi Network even when Guest Networks are disabled. I trraced the issue to one of my 3 satelittes - an RBS50Y. Netgear lists two firmwar...
Apr 07, 2021Guru - Experienced User
Did you factory reset the RBSY unit after the FW is updated and then set it up from scratch to see if the GN still appears?
Vandergraff
Apr 07, 2021Apprentice
FURRYe38 wrote:Did you factory reset the RBSY unit after the FW is updated and then set it up from scratch to see if the GN still appears?
Yes
