Vandergraff
Apr 06, 2021Apprentice
Netgear-Guest Open and Disabling Firmware Updates
As many have reported I often see a Netgear-Guest Open WiFi Network even when Guest Networks are disabled. I trraced the issue to one of my 3 satelittes - an RBS50Y. Netgear lists two firmwar...
Sundried
May 10, 2021Aspirant
One thing to add on all of this - I had the same problem on the RBS50Y re the netgear_guest, and it was on regardless of having the guest network enabled or not on the other satellites with a different SSID when version 2.6.2.104 was installed
Taking the satellite back to 2.3.5.32 solved the issue. However, one thing I discovered after I went back to the prior firmware is that the latest version seemed to be stored in the satellite - so on reset to factory settings the firmware seems to be upgraded back to the latest version that causes the issue (this may explain some of the comments re the firmware is automatically updated). It looks like on reset to factory settings you then also need to do a re application of the older firmware version.
Sundried
May 11, 2021Aspirant
To be clear - not complaining about auto updates - I was prompted to take the latest firmware and agreed.
The complaint would be that the most recent firmware has a bug in it that seems to create an open guest network on the rbs50y outdoor satellite.
This is fixed by going back to the previous version of the firmware - which would imply it is a bug somewhere (or there are a lot of users out there who don’t know how to use the system as it seems to be a common problem with these outdoor devices)
However, if you do a factory reset the satellite seems to auto install the latest version of the firmware and so the issue comes back. Easily solved by reinstalling the earlier firmware, but irritating.
It is only an issue with the outdoor 50y - I have three other indoor satellites and these do not suffer from the issue
