Vandergraff
Apr 06, 2021Apprentice
Netgear-Guest Open and Disabling Firmware Updates
As many have reported I often see a Netgear-Guest Open WiFi Network even when Guest Networks are disabled. I trraced the issue to one of my 3 satelittes - an RBS50Y. Netgear lists two firmwar...
Sundried
May 10, 2021Aspirant
One thing to add on all of this - I had the same problem on the RBS50Y re the netgear_guest, and it was on regardless of having the guest network enabled or not on the other satellites with a different SSID when version 2.6.2.104 was installed
Taking the satellite back to 2.3.5.32 solved the issue. However, one thing I discovered after I went back to the prior firmware is that the latest version seemed to be stored in the satellite - so on reset to factory settings the firmware seems to be upgraded back to the latest version that causes the issue (this may explain some of the comments re the firmware is automatically updated). It looks like on reset to factory settings you then also need to do a re application of the older firmware version.
Vandergraff
May 11, 2021Apprentice
Yes that is probably what I was seeing. Per FURRYe38 recommendations I (repeatedly) tried doing a factory reset. That was probably what kept loading the latest firmware.
Going back to 2.3.5.32 always solved the issue - no recent factory resets and still on 2.3.5.32 and everything good on the outdoor RBS50Y - and yes it's just the RBS50Y. My other RBS50 satellites run fine on their latest firmware.
- Blanca_OMay 20, 2021NETGEAR Employee Retired
Hi, All,
This has been brought up already and the product team are investigating on the issue.
Vandergraff Retired_Member Sundried
Please check your inbox. I have sent you a message requesting for more information.Regards,
Blanca
Community Team- Retired_MemberMay 20, 2021Hi after weeks and weeks of issues with the Orbi system I kicked of my house. I will never buy a netgear product. Since I bough the junk I had only troubles. FW does not work properly satellite did. no connect wlan troubles. And the support from netgear is the worst I have ever experienced
- FURRYe38May 21, 2021Guru - Experienced User
Please mark your thread as solved so others will know.
Enjoy.
Vandergraff wrote:
Sundried wrote:Taking the satellite back to 2.3.5.32 solved the issue. However, one thing I discovered after I went back to the prior firmware is that the latest version seemed to be stored in the satellite - so on reset to factory settings the firmware seems to be upgraded back to the latest version that causes the issue (this may explain some of the comments re the firmware is automatically updated). It looks like on reset to factory settings you then also need to do a re application of the older firmware version.
- VandergraffMay 22, 2021Apprentice
FURRYe38 but it is not solved. If I use the latest firmware on the RBS50Y then the issue is there. Only by going back to an older version of firmware does the issue go away. I should be able to run the latest (and presumably most secure) firmware on the RBS50Y.
Netgear support has reached out to see if we can find out more about what is going on.
Thanks
- FURRYe38May 23, 2021Guru - Experienced User
Let us know how it goes...
