Vandergraff
Apr 06, 2021Apprentice
Netgear-Guest Open and Disabling Firmware Updates
As many have reported I often see a Netgear-Guest Open WiFi Network even when Guest Networks are disabled. I trraced the issue to one of my 3 satelittes - an RBS50Y. Netgear lists two firmwar...
Retired_Member
Jul 09, 2021I'm having the same issue. Netgear-Guest Open WiFi Network even with guest network turned off. This is frustrating. When will a fix be avaible?
Jul 09, 2021Guru - Experienced User
Please contact a forum moderator for help and information regarding this:
Thank you.
Retired_Member wrote:I'm having the same issue. Netgear-Guest Open WiFi Network even with guest network turned off. This is frustrating. When will a fix be avaible?
