Vandergraff
Apr 06, 2021Apprentice
Netgear-Guest Open and Disabling Firmware Updates
As many have reported I often see a Netgear-Guest Open WiFi Network even when Guest Networks are disabled. I trraced the issue to one of my 3 satelittes - an RBS50Y. Netgear lists two firmwar...
pdeethardt
Jul 14, 2021Apprentice
I just added a new RBS50Y and updated to firmware 2.6.2.104, and I'm seeing the same issue with both the Netgear-Guest SSID and the SSID I created for my guest network both being broadcast without the guest network being enabled. I realize a fix is in the works, but I just wanted to chime in.
I did try connecting to both of the guest SSIDs, and I noticed that they do not have a internet connection, so they appear to be more of an annoyance than a security issue. I also tried manually configuring my network settings to see if I could get internet access on either SSID, and no dice.
- FURRYe38Jul 14, 2021Guru - Experienced User
Please contact a forum moderator for help and information regarding this:
pdeethardt wrote:I just added a new RBS50Y and updated to firmware 2.6.2.104, and I'm seeing the same issue with both the Netgear-Guest SSID and the SSID I created for my guest network both being broadcast without the guest network being enabled. I realize a fix is in the works, but I just wanted to chime in.
- jrsheetsJul 28, 2021TutorThis is happening to me also.. Any Fix??? ON the latest version of the RBS50Y Firmware. Thanks
