Vandergraff
Apr 06, 2021Apprentice
Netgear-Guest Open and Disabling Firmware Updates
As many have reported I often see a Netgear-Guest Open WiFi Network even when Guest Networks are disabled. I trraced the issue to one of my 3 satelittes - an RBS50Y. Netgear lists two firmwar...
pdeethardt
Jul 14, 2021Apprentice
I just added a new RBS50Y and updated to firmware 2.6.2.104, and I'm seeing the same issue with both the Netgear-Guest SSID and the SSID I created for my guest network both being broadcast without the guest network being enabled. I realize a fix is in the works, but I just wanted to chime in.
I did try connecting to both of the guest SSIDs, and I noticed that they do not have a internet connection, so they appear to be more of an annoyance than a security issue. I also tried manually configuring my network settings to see if I could get internet access on either SSID, and no dice.
Jul 14, 2021Guru - Experienced User
Please contact a forum moderator for help and information regarding this:
pdeethardt wrote:I just added a new RBS50Y and updated to firmware 2.6.2.104, and I'm seeing the same issue with both the Netgear-Guest SSID and the SSID I created for my guest network both being broadcast without the guest network being enabled. I realize a fix is in the works, but I just wanted to chime in.
- jrsheetsJul 28, 2021TutorThis is happening to me also.. Any Fix??? ON the latest version of the RBS50Y Firmware. Thanks
- FURRYe38Jul 28, 2021Guru - Experienced User
jrsheets wrote:
This is happening to me also.. Any Fix??? ON the latest version of the RBS50Y Firmware. Thanks- jrsheetsJul 28, 2021TutorWhy would we contact a forum moderator for this? It would seem that posting the problem on here and then the moderator (or others) responding to the issue on here would be much more beneficial than sending a PM to a moderator. If the response is always contact a moderator, what is the point of having a community forum? That completely negates the whole point of a forum. Is this some triple top secret problem / solution that shouldn’t be public?
