Rob-
Apr 24, 2021Aspirant
NETGEAR-GUEST wifi SSID broadcast from RBS50Y although this SSID is not set up on my RBR50 Router
Hi I wonder if someone can offersome help? When my RSB50Y is on V2.6.2.40 my main network and guest network are fine, but as soon as it auto updates to V2.6.2.104 I have a new OPEN unsecured ss...
Apr 24, 2021Guru - Experienced User
Be sure that the guest network enable and enable guest network broadcast are uncheck on the RBR unit.
Has a factory reset been performed on the entire orbi system after last FW update?
