Rob-
Apr 24, 2021Aspirant
NETGEAR-GUEST wifi SSID broadcast from RBS50Y although this SSID is not set up on my RBR50 Router
Hi I wonder if someone can offersome help? When my RSB50Y is on V2.6.2.40 my main network and guest network are fine, but as soon as it auto updates to V2.6.2.104 I have a new OPEN unsecured ss...
CrimpOn
Apr 24, 2021Guru - Experienced User
This is just so different from my experience. Although I do not have an RBS50Y, I recently spent all afternoon loading various firmware on an Orbi router (about 10 versions if I recall correctly). Although it would complain when the upload version was "older" than what was on the router, every single time the router rebooted with the version I had manually loaded.
Rob-
Apr 25, 2021Aspirant
Hi All
I seemed to have addressed the issue for the present. I turned off my guest WIFI and rebooted everything. However, the RBS50Y was still broadcasting the guest wifi. I used telnet nvram command to reset the RBS50Y to factory then re-synced the RBS50Y and now appears OK.
Thanks for all you suggestions.
- RadzMay 15, 2021Aspirant
Hi, I have this exact problem. I have reset using the reset button with no success. I have some basic comp skills but am unfamiliar with the telnet nvram method you used. I am on a Mac using MacOS 10.15.7.
Any help would be greatly appreciated.
- Blanca_OMay 20, 2021NETGEAR Employee Retired
Hi Radz
This has been brought up already to the team and will report back with an update as soon as possible.
Related thread: https://community.netgear.com/t5/Orbi/Netgear-Guest-Open-and-Disabling-Firmware-Updates/m-p/2097641#M120822
Blanca
Community Team- computersteveJul 06, 2021Apprentice
This is still happening. I'm on the latest firmware & theres a phantom Guest Network being broadcast on the RBS50Y both bands 2.4/5g called NETGEAR-GUEST.
