Ulairi
Jun 08, 2018Luminary
Netgear Have Closed Support Case WITHOUT RESOLUTION
Per this thread I have an enduring problem with my RBW30 Wall plug satellite. That was one of two problems that I had the was speed throttling, which was solved by two factory resets.
I am com...
Retired_Member
Jun 08, 2018Same thing happened to my support case. Netgear changed their website without notifying users so the current support system is effectively broken. The case still exists I believe, but the website doesn't show them now. This is what happens when companies do not communicate to their users, as well as other departments properly.
