PapaTed
Aug 20, 2019Follower
Netgear Irbi rbk50...does this actually work with Canadian network providers?...Specifically Bell.
We are in a remote area and can only get a download speed of 5mbps. Streaming buffers constantly. Using Chromecast helps significantly but still doesn't eliminate the buffering problem.
Help!!!
1 Reply
Orbi works with most ISPs. Also depends if your ISP modem having a built in wifi router as well. Also streaming on a 5Mb maybe your other cause of problems. This is fairly slow for stream and downloading videos. Also if others are online at the same time streaming videos on this kind of ISP speed, this will be another factor.
