LloydG
Jan 18, 2021Aspirant
Netgear LBR20 Prime video and website problmes
Evening all. Has anyone experienced any problems streaming Amazon Prime with this router , it seems the only device that I don't have problems with is a roku. I'm also having issues just loading webp...
Blanca_O
Feb 22, 2021NETGEAR Employee Retired
Hi LloydG
Welcome to NETGEAR Community!
We wanted to check if you still experience the issue.
What is the firmware version?
Have you tried factory resetting the unit?
Blanca
Community Team
- energieMar 10, 2021Luminary
It seems you are experiencing the same error as described here:
There is an issue with the DNS server / firmware. As a user you cannot fix this. Only thing that is available are workaround that bypass the Orbi's DNS Server / firmware. Only Netgear can fix the actual problem.
Netgear should fix the DNS server / firmware.
