whereupon
May 14, 2019Aspirant
Netgear modem w/separate Orbi...logging into modem
Setting up a new modem/wifi system. Needed a modem w/voice because my wife uses a landline. So, got a CM1150V modem, then got the RBK50 wifi router and satellite. I have two computers connected to...
- May 14, 2019
Change back to .1.1 and while the Orbi reboots, power OFF the modem for 30 seconds then back on.
May 14, 2019Guru - Experienced User
You only need to use the default IP address for the Orbi or you can use 192.168.0.1. Don't use .100.#
You should get ISP modem access thru the Orbi at 192.168.100.1 for any modem that defaults to this IP address when a router is connected.
When the Orbi is using 192.168.1.1, can you ping 192.168.100.1 with a wired PC oonnected to the Orbi?
whereupon
The CM1150V modem is at 192.168.100.1 by default.
The Orbi is now at 192.168.100.2, with a DHCP range of .3-.254.
The computer cabled into the Orbi is at 192.168.100.7, and can ping the Orbi at .2, but cannot ping the modem at 192.168.100.1.
I can put the Orbi back to default values and try it.
- FURRYe38May 14, 2019Guru - Experienced User
- whereuponMay 14, 2019Aspirant
It worked...turns out I was trying to solve a problem that didn't yet exist.
thanks!
Glad it's working. Enjoy. :smileywink:
