whereupon
May 14, 2019Aspirant
Netgear modem w/separate Orbi...logging into modem
Setting up a new modem/wifi system. Needed a modem w/voice because my wife uses a landline. So, got a CM1150V modem, then got the RBK50 wifi router and satellite. I have two computers connected to...
- May 14, 2019
Change back to .1.1 and while the Orbi reboots, power OFF the modem for 30 seconds then back on.
whereupon
The CM1150V modem is at 192.168.100.1 by default.
The Orbi is now at 192.168.100.2, with a DHCP range of .3-.254.
The computer cabled into the Orbi is at 192.168.100.7, and can ping the Orbi at .2, but cannot ping the modem at 192.168.100.1.
I can put the Orbi back to default values and try it.
