shkwa42
Jul 24, 2020Follower
Netgear Nighthawk AX80 + Orbi RBK50
I just bought a Nighthawk AX80 modem/router to replace a very old Motorola modem that finally died. I currently also have an Orbi RBK50 system in place as my router and mesh system. Any issues with s...
Jul 30, 2020Guru - Experienced User
You can use the RBK50 in AP mode while the CAX80 modems wifi is disabled for best operation and performance, or configure the CAX80 for modem mode only and configure the RBK50 for router mode behind the CAX80.
shkwa42 wrote:I just bought a Nighthawk AX80 modem/router to replace a very old Motorola modem that finally died. I currently also have an Orbi RBK50 system in place as my router and mesh system. Any issues with still using the Orbi as a mesh system to boost throughout the house with the Nighthawk?
Thanks.
