arien888
Jun 04, 2019Follower
netgear nighthawk x4s r7800 wireless router
Hi, I currently have netgear nighthawk x4s r7800 wireless router, my question is: what will be the compatible wifi mesh device that will work with it ? Will Orbi Wifi mesh devices work with R780...
michaelkenward
Jun 05, 2019Guru - Experienced User
arien888 wrote:
Will Orbi Wifi mesh devices work with R7800 ?
Yes. I have an Orbi router and three satellites sitting behind an R7800.
But, and this is important, the Orbi is in AP mode. That avoids the curse of the "double NAT".
I could ditch the R7800, but the Orbi does not support ReadyShare.
Interestingly, even in AP mode the Orbi supports some of the features that will not work in standard routers.
