computersteve
Oct 04, 2020Apprentice
Netgear NTP servers down?
Both my RBS50Y and my Orbi Router RBR50 are stating that they cant connect to the Netgear NTP server. I'm in New York on Long Island & this is the Warning: The Orbi Router failed to connect to NTP se...
CrimpOn
Oct 04, 2020Guru - Experienced User
computersteve wrote:Both my RBS50Y and my Orbi Router RBR50 are stating that they cant connect to the Netgear NTP server. I'm in New York on Long Island & this is the Warning: The Orbi Router failed to connect to NTP server, please check your internet connectivity or try another NTP server.
Google found me this site that checks ntp servers:
https://keetweej.vanheusden.com/query_ntp.php
When I checked, time-a.netgear.com, time-b.netgear.com, and time-c.netgear.com all report status. You might check and see what it reports for you.
Perhaps it would be worth trying to use a different ntp server. Popular ones are listed here:
https://tf.nist.gov/tf-cgi/servers.cgi
The Orbi ntp server is set on the Orbi web interface Advanced Tab, Administration, NTP Settings.
