computersteve
Oct 04, 2020Apprentice
Netgear NTP servers down?
Both my RBS50Y and my Orbi Router RBR50 are stating that they cant connect to the Netgear NTP server. I'm in New York on Long Island & this is the Warning: The Orbi Router failed to connect to NTP se...
Oct 04, 2020Guru - Experienced User
Have you rebooted your ISP modem and the RBR to see if this changes anything?
Try using a manual NTP server.
My RBR50 in AP mode is reporting same:
Warning: The Orbi Router failed to connect to NTP server, please check your internet connectivity or try another NTP server.
Just tried time.nist.gov and that works. |
computersteve
I tried. Still reporting the same thing. It’s something with netgear servers. All my other devices using non-Netgear ntp servers are working (Windows, Apple)
- MstrbigOct 04, 2020Master
computersteve wrote:
I tried. Still reporting the same thing. It’s something with netgear servers. All my other devices using non-Netgear ntp servers are working (Windows, Apple)I use Netgear's Time servers and have no issues. So it may be that a hub is down in your area preventing you from getting to a series of Domains/IP addresses. This happens sometimes here where they are Hurricanes around.
If it doesn't clear up, change to another server.
- computersteveOct 04, 2020Apprentice
So, It seems to have gone away. Meaning its working now =) Thanks.
- FURRYe38Oct 04, 2020Guru - Experienced User
Mines still reporting it can't connect. I'll check it this a bit later.
