Sival
Feb 20, 2017Aspirant
netgear orbi - Hangs, satellite magenta and main unit no light. happens randomly every few days.
i have my orbi with one satellite running for 2 weeks. saw the system hang 4 times randomly. Each time satellite has magenta light and main unit has no light. Nothing works when this happens until I restart both satellite and main unit (power off -on). I checked logs no clues, I have them pasted below. I have latest firmware you can see that below.
Is this hapening to others ? Do you have any solution?
1 Reply
- SivalAspirant
Orbi logs after restart. connectivity lost around 2 PM until i restarted around 4PM. I am also not sure if these DoS attacks are real, or intepreted from my VPN connection to a server in another region.
[remote login] from source 192.168.1.7, Monday, February 20, 2017 16:54:05
[UPnP set event: add_nat_rule] from source 192.168.1.7, Monday, February 20, 2017 16:53:12
[UPnP set event: del_nat_rule] from source 192.168.1.7, Monday, February 20, 2017 16:53:08
[DHCP IP: 192.168.1.7] to MAC address fc:f8:ae:0:c1:ed, Monday, February 20, 2017 16:53:01
[DoS Attack: ACK Scan] from source: 40.97.10.5, port 58309, Monday, February 20, 2017 16:47:55
[DoS Attack: TCP/UDP Chargen] from source: 185.18.40.174, port 54586, Monday, February 20, 2017 16:41:28
[DoS Attack: ACK Scan] from source: 40.97.16.5, port 31636, Monday, February 20, 2017 16:40:01
[DoS Attack: ACK Scan] from source: 122.24.62.46, port 25261, Monday, February 20, 2017 16:12:15
[DoS Attack: ACK Scan] from source: 40.7.140.197, port 20060, Monday, February 20, 2017 16:06:50
[DHCP IP: 192.168.1.16] to MAC address f0:d5:bf:7:30:c2, Monday, February 20, 2017 16:06:06
[DoS Attack: ACK Scan] from source: 40.6.35.229, port 56550, Monday, February 20, 2017 16:04:21
[DoS Attack: ACK Scan] from source: 5.14.13.50, port 13765, Monday, February 20, 2017 16:01:54
[UPnP set event: del_nat_rule] from source 192.168.1.7, Monday, February 20, 2017 15:52:32
[UPnP set event: add_nat_rule] from source 192.168.1.7, Monday, February 20, 2017 15:51:44
[DHCP IP: 192.168.1.7] to MAC address fc:f8:e:a0:c1:ed, Monday, February 20, 2017 15:51:41
[DHCP IP: 192.168.1.7] to MAC address fc:f8:e:a0:c1:ed, Monday, February 20, 2017 15:51:39
[DHCP IP: 192.168.1.12] to MAC address 5c:7:f3:a4:e2:00, Monday, February 20, 2017 15:46:46
[DHCP IP: 192.168.1.12] to MAC address 5c:7:f3:a4:e2:00, Monday, February 20, 2017 15:46:45
[DHCP IP: 192.168.1.12] to MAC address 5c:7:f3:a4:e2:00, Monday, February 20, 2017 15:36:50
[DoS Attack: SYN/ACK Scan] from source: 2.7.248.149, port 27055, Monday, February 20, 2017 15:31:29
[DoS Attack: ACK Scan] from source: 4.97.162.149, port 29044, Monday, February 20, 2017 15:26:14
[DHCP IP: 192.168.1.11] to MAC address 5c:7:f3:a6:92:2e, Monday, February 20, 2017 15:24:09
[DHCP IP: 192.168.1.21] to MAC address 20:a:37:86:ca:65, Monday, February 20, 2017 15:23:04
[DHCP IP: 192.168.1.21] to MAC address 20:a:37:86:ca:65, Monday, February 20, 2017 15:20:11
[DoS Attack: ACK Scan] from source: 72.30.25.6, port 443, Monday, February 20, 2017 15:10:39
[DoS Attack: RST Scan] from source: 222.252.5.229, port 44448, Monday, February 20, 2017 15:09:50
[DoS Attack: ACK Scan] from source: 40.97.13.229, port 20277, Monday, February 20, 2017 15:06:37
[DoS Attack: ACK Scan] from source: 40.97.10.197, port 61091, Monday, February 20, 2017 14:53:27
[UPnP set event: add_nat_rule] from source 192.168.1.7, Monday, February 20, 2017 14:51:43
[UPnP set event: del_nat_rule] from source 192.168.1.7, Monday, February 20, 2017 14:51:40
[DHCP IP: 192.168.1.7] to MAC address fc:f:ae:a0:c1:ed, Monday, February 20, 2017 14:51:36
[DHCP IP: 192.168.1.128] to MAC address 74:f:bf:b0:ea:cd, Monday, February 20, 2017 14:23:20
[DoS Attack: ACK Scan] from source: 132.245.3.165, port 22222, Monday, February 20, 2017 14:19:36
[DHCP IP: 192.168.1.21] to MAC address 20:b:37:86:ca:65, Monday, February 20, 2017 14:10:44
[DoS Attack: ACK Scan] from source: 40.97.8.21, port 32272, Monday, February 20, 2017 14:03:08
[DHCP IP: 192.168.1.18] to MAC address 50:5:da:e8:09:34, Monday, February 20, 2017 13:56:11
[DHCP IP: 192.168.1.10] to MAC address ac:f:3e:94:7a:d6, Monday, February 20, 2017 13:54:33
[admin login] from source 192.168.1.7, Monday, February 20, 2017 13:54:30
[DHCP IP: 192.168.1.9] to MAC address a4:8:05:ea:d3:77, Monday, February 20, 2017 13:54:26
[UPnP set event: add_nat_rule] from source 192.168.1.7, Monday, February 20, 2017 13:53:29
[DHCP IP: 192.168.1.7] to MAC address c:f8:ae:a0:c1:ed, Monday, February 20, 2017 13:53:21
[DHCP IP: 192.168.1.6] to MAC address 0:f5:da:65:06:00, Monday, February 20, 2017 13:52:47
[DHCP IP: 192.168.1.4] to MAC address c:3d:cf:f3:6f:48, Monday, February 20, 2017 13:52:46
[DHCP IP: 192.168.1.5] to MAC address 4:61:32:e5:09:06, Monday, February 20, 2017 13:52:45
[DHCP IP: 192.168.1.4] to MAC address c:3d:cf:f3:6f:48, Monday, February 20, 2017 13:52:45
[DHCP IP: 192.168.1.5] to MAC address 4:61:32:e5:09:06, Monday, February 20, 2017 13:52:44
[DHCP IP: 192.168.1.3] to MAC address 4:77:33:7d:6b:3e, Monday, February 20, 2017 13:52:33
[DHCP IP: 192.168.1.2] to MAC address 0:24:2c:46:a:69, Monday, February 20, 2017 13:52:31
[Time synchronized with NTP server] Monday, February 20, 2017 13:52:16
[DHCP IP: 192.168.1.145] to MAC address 00:90:9:b7:b2:86, Monday, February 20, 2017 13:52:12
[Internet connected] IP address: 24.2.11.7, Monday, February 20, 2017 13:52:10
[Initialized, firmware version: V1.4.0.34] Monday, February 20, 2017 13:52:06
