baba_net
Aug 25, 2021Follower
Netgear Orbi - Trunk/ 802.1q
Hi folks, I am interested by Netgear Orbi product familly but i need to be able to configure vlans. I am using different vlans at home in order to separate my IOT (camera, etc.), guest wifi, etc. s...
Aug 25, 2021Guru - Experienced User
You might check out Orbi Pro for this kind of question:
https://community.netgear.com/t5/Orbi-Pro-WiFi-for-Small-Business/bd-p/en-business-pro-wifi
baba_net wrote:
Hi folks,
I am using different vlans at home in order to separate my IOT (camera, etc.), guest wifi, etc. so i am using 5 Vlans and tagged ports to connect to my switch.
My question is : Does your product vlan tagging on network ports on the router and also on the WIFI ? ( 1 SSID = 1 VLAN) ?
Few years ago it was not the case but i haven't been able to find a answer to this that is recent. Otherwise, is it in your roadmap ?
Thanks.
Regards.
