pazobeach
Jul 18, 2019Follower
Netgear Orbi 2.2Gbps - AC2200/(RBK23)
I live in a 2 stories house (about 4000sq ft) and I am considering to buy the Netgear Orbi Whole Home Mesh Wifi System AC2200(RBK23). I have a modem/router all in one (Arris DG1670) provided by my ca...
Jul 18, 2019Guru - Experienced User
Modem Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
