Tib78
Jun 03, 2021Star
Netgear Orbi 85X - WPA3 avec WPA2 en simultané
Bonjour, Est-il possible d'activer le WPA3 avec le protocole WPA2 en simultané, certains périphériques (comme les Nest Cam par ex) ne fonctionnent pas en WPA3, or le routeur Orbi ne propose pas l...
Jun 03, 2021Guru - Experienced User
en anglais s'il vous plaît
Netgear has set up a community forum specifically for the Orbi AX (WiFi 6) products. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Thank you.
