Andreas_Sweden
Mar 17, 2020Aspirant
Netgear Orbi AC3000 - Telia IPTV not working
Dear Netgear Community, I have a Orbi AC3000 system at home with one router and two satelites.The router is located at the ground floor in my house, and the two satelites located on the second fl...
CrimpOn
Mar 17, 2020Guru - Experienced User
Andreas_Sweden wrote:My problem is that I can't get IPTV with Telia (Sweden) working with ny Orbi AC3000 system.
Telia is supposed to provide their requirements. A quick Google search turned up this information about the Netgear Nighthawk router.
My guess is the Orbi setup is similar.
https://kb.netgear.com/29911/Configuring-VLAN-IPTV-setup-on-your-Nighthawk-router
Andreas_Sweden
Mar 25, 2020Aspirant
Hi,
I tried the solution but I couldn't make it work. When I tried the solution for Netgear Nighthawk on my system, internet didn't work and IPTV didn't work either.
Do you have any other possible solution to try?
Also, on my RBR50 (router) I have 4 network connections, on the satelites I only have 3 network connection it this is valuable input.
BRs
Andreas
- CrimpOnMar 25, 2020Guru - Experienced User
Page 84-85 of the Orbi User Manual have an explanation of how to set up for IPTV. They also say the ISP may have specific instructions.
http://www.downloads.netgear.com/files/GDC/RBK50/Orbi_UM_EN.pdf
