mariogaucher
Jul 04, 2019Aspirant
Netgear Orbi AC3000 channel selection in Canada
Hello Everyone! I just installed an Orbi AC3000 router+satellite to replace my Asus AiMesh routers that were rebooting ramdomly. So far, it works fine. Setup was fast and easy. One thing I'...
schumaku
Jul 04, 2019Guru - Experienced User
No idea which channels (including DFS) should be available for the user-facing 5 GHz radios.
Please keep in mind that Orbi does reserve and use the high channels for its wireless backhaul - which does run on a dedicated radio on each Orbi router and Orbi satellite.
- mariogaucherJul 04, 2019AspirantThanks for your answer.
There’s no way to see which channels are used for the backhaul...
I guess it makes sense now.- CrimpOnJul 04, 2019Guru - Experienced User
If telnet is enabled on the Orbi debug page (xxx.xxx.xxx.xxx/debug.htm) you can telnet to the router and enter:
wlanconfig ath2 list
It will show the backhaul channel, rate, and other things.
- mariogaucherJul 04, 2019AspirantGreat thanks!
Using channel 157... and current rate is 975/975...
Not bad considering both devices are like 40-50 feet away from each other and two external wall between them (the satellite is installed in my neighbors’ house).
