mariogaucher
Jul 04, 2019Aspirant
Netgear Orbi AC3000 channel selection in Canada
Hello Everyone! I just installed an Orbi AC3000 router+satellite to replace my Asus AiMesh routers that were rebooting ramdomly. So far, it works fine. Setup was fast and easy. One thing I'...
mariogaucher
Thanks for your answer.
There’s no way to see which channels are used for the backhaul...
I guess it makes sense now.
CrimpOn
Jul 04, 2019Guru - Experienced User
If telnet is enabled on the Orbi debug page (xxx.xxx.xxx.xxx/debug.htm) you can telnet to the router and enter:
wlanconfig ath2 list
It will show the backhaul channel, rate, and other things.
- mariogaucherJul 04, 2019AspirantGreat thanks!
Using channel 157... and current rate is 975/975...
Not bad considering both devices are like 40-50 feet away from each other and two external wall between them (the satellite is installed in my neighbors’ house).
