orbira
Jan 12, 2019Apprentice
NETGEAR Orbi AC3000 satellite LAN ports stopped working
Hi I am using Orbi router for last 2 months just fine. Today morning the LAN port son router suddenly stopped working. One of the satellite was connected over wired backhaul, that also switched to ...
- Jan 13, 2019
What wired devices are connected to the LAN ports?
What is the Mfr and model# of the ethernet switch if one is in the configuration.
Had the Orbi been powered OFF (pull power adapter from wall outlet) for 1 minute with out anything connected to the LAN ports, then powered ON with maybe just one wired PC connected to the same LAN port and test the others to see if the port is working or failing?
Swap LAN cables as well.
orbira
Jan 13, 2019Apprentice
I think so too. How did you fix your issue? In my case, I have tried everything...
rwright727 wrote:
The issue may not be device hardware related. My RBS50 Satellite went out last night also. None of my lan ports are working and if a device is conected wirelessly, I can't get safari to open pages and receive a SSL certificate error
rwright727
Jan 13, 2019Tutor
I don't have it working yet. I manually applied the latest firmware (V2.2.1.210) and orbilogin.com reports "Update failed."
- orbiraJan 13, 2019ApprenticeI was running the latest firmware but still went ahead and reapplied it just to rule out any corruption, but still no luck.
