killians913
Jun 04, 2017Aspirant
NETGEAR Orbi AC3000 satellite LAN ports
I keep hearing that the LAN ports on the satellite units do not work. Is that correct? If so, when will they be activated and be useful?
- Jun 04, 2017
The LAN ports do work. The USB ports do not.
st_shaw
Jun 04, 2017Master
killians913
Jun 05, 2017Aspirant
Thanks so much for your response to my query. So you're saying that I can connect a basement computer to one of the satellites via the LAN port? How will the LAN connection be degraded?
- st_shawJun 05, 2017Master
Absolutely, you can connect a wired computer to the Satellite's LAN port. That's what they are there for. I wouldn't say the LAN connection is "degraded," but the speed will be limited based on the other device you are connecting to over the LAN.
1. Between two computers connected to the Satellite's LAN ports you will get full gigabit LAN speed. Throughput should be >900 Mbps.
2. Between a computer connected to the Satellite's LAN port and a computer connected to the Router's LAN port you will get the Orbi Backhaul speed. Throughput should be 500 Mbps or greater for a good backhaul connection.
3. Between a computer connected to the Satellite's LAN port and a computer connected via Orbi WiFi, the speed will be limited by the WiFi client's connection.
