mongotz
Jan 28, 2020Aspirant
NETGEAR Orbi AC3000 Tri-band Wi-Fi System maximum satelittes
I have the system set up with the main router, the two satellites that came with the package and an RBS50Y outdoor router to make up 3 satellites. My ring doorbell is just not recieving enough signa...
mongotz
Jan 30, 2020Aspirant
FIRMWARE 2.3.5.22
Arris Optimum Modem TM1602A
Home 3500 sq ft
All units stacked on 3 floors above each other, outdoor one in garage.
Router settings cannot be discerned thru Optimum
I have app on phone but don't see how to change channels but have done before with other routers
No Armor or any of that type.
Bell connection for viewing is on and off when I try to access and alert works fine when someone comes to the door. Alerts thru all Alexa devices. Connected to doorbell power, battery constant charge (Ring 2)
Bell shows signal strength of RSSI-49
Jan 30, 2020Guru - Experienced User
That size of home having two is enough. I'd maybe turn OFF one and test.
To change channels on the Orbi system you have to log into the RBRs web page at orbilogin.com with a PC or laptop with a web browser.
Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Also you might update FW on the RBS then RBR at some point. v2.5.1.8 is currently released and most stable.
