LenaWood
Nov 03, 2018Aspirant
NETGEAR Orbi AC3000 Tri-band Wi-Fi System
We have 3 buildings (2 brick houses (800 sq ft & 500 sq ft) and a Metal Shop (24' X 48') on our property that is approx 100' X 120'. We are interested in the NETGEAR Orbi AC3000 Tri-band Wi-Fi Syste...
LenaWood
I believe the system we would be purchasing comes with 2 sattelites and the router. How far apart can the pieces of equipment be from each other and still work properly?
Thanks for the information given so far.
Lena
ekhalil
Nov 03, 2018Master
Lena
30 feet is recommended, but you can have up to 40-50 feet distance before the backhaul signal stregth starts to degrade.
Of course, you can have a longer distance if you use wired backhaul instead.
- LenaWoodNov 04, 2018Aspirant
Thank you for your help!
