smilepak
Aug 12, 2019Tutor
Netgear Orbi and ATT Pace 5268 Router
Using the Netgear Orbi, is using the Pace 5268 w/ DMZ+ better or using the Arris with IP Passthrough, which one would allow maximization of the 1gbps speed of the ATT fiber. The issue I am faced with...
smilepak
Aug 12, 2019Tutor
Thanks. I think I am using #2 right now with the DMZ+ with the Pace 5268. Unfortunately the Pace nor anyone of ATT routers support true bridge mode. The DMZ+ is basically a form of IP pass through that forward all traffics on all ports to the one connection to the Orbi.
Aug 12, 2019Guru - Experienced User
Others posted about this same model modem...
Does your ISP support a stand alone modem option? This would be prefferred over the gateway modem for use with the Orbi system.
- smilepakAug 12, 2019Tutor
FYI for anyone who has similar problem. This fixed the slow download issue I am having between the Netgear Orbi and ATT Pace 5268. I am not getting the 800mbps that I get if connected directly to the ATT router, but I am getting 500-600mbps. Much better than what I was getting before.
https://forums.att.com/t5/AT-T-Fiber-Equipment/PACE-11-1-0-531418-DMZ-Issue/m-p/5745153#M7940
- FURRYe38Aug 13, 2019Guru - Experienced User
Good to hear. Glad it's working better now. Thanks for letting us know. Please mark your thread and solved so others will know.
Enjoy. :smileywink:
